I’m new to the course, hence just getting started. In following the course material to setup a Virtual Machine with Ubuntu on my Windows 10 PC, I see both Ubuntu 16.04 and Ubuntu 18.04 mentioned. But this warning directly below in the “IMPORTANT SPFTWARE VERSION INFORMATION!” section of the course makes me not certain which version of Ubuntu Caleb developed the code in. Caleb, can you answer this question ? I’d welcome answers from anyone else as well.
IMPORTANT!! DO NOT UPGRADE TO UBUNTU 20!!
After you install and launch Ubuntu 16 on your Virtual Machine and first login, you will at some point be prompted to upgrade to Ubuntu 18.04. DO NOT DO THIS!!! The course material has only been tested on Ubuntu 16.04, and you will likely run into bugs on Ubuntu 18.04. Upgrade at your own peril
