When I connect the battery, I expect the servo motor to go to the middle. Center itself so that the wheels are corrected to be straight.
I am not getting any reaction from the servo. Wondering if anyone knows why and/or what they suggest doing.
I am experiencing the same problem. Any response from the community?
I’ve asked Caleb to chime in. Meanwhile, here is the AI response:
Verify the servo is plugged into the correct port and in the correct direction; a reversed connector can make it look dead .
Make sure the servo rail actually has 5V available, because a servo won’t center without proper rail power .
Confirm the battery is connected and not just USB power, since USB alone may not move the servo .
Check that the ground wire from the battery/ESC and the controller is common with the servo ground; missing common ground is a frequent cause of no response .
If the servo has no motion at all, test it standalone or swap it with a known-good servo to separate wiring issues from servo failure
