Been working on this for a few days now. Attached is the picture of the electronics soldered together per the diagram (with one exception, of flipped TX RX wires on the gps connection while troubleshooting.)
Problems:
Pi-zero cannot get heartbeat from FC
GPS is on but not talking to the FC at all.
What I tried:
I configured the FC via Adrupilot for the PI Z to be on UART 3 (SERIAL 2) and the GPS on UART 5 (SERIAL 3)
Telemetry seems to be fine per Adrupilot and the radio syncs just fine
I spent roughly 12 hours with chatgpt and google. Please provide another way forward. I am out of ideas to finish this thing.
Also, there was a separate connector that came on the GPS that had two wires on it. Caleb’s diagram showed these connecting to the last two pins, next to the Power, GND, RX, TX wires. So I connected as shown, although the colors were different, I assumed blue = white, pink = orange… Are these passive? Required?
Could they be the culprit ?
And this is how you are connecting the GPS?
The other two wires (SCL, SDA) are for the compass.
I looked at ChatGPT as well. It suggests not to connect the GPS to Tx/Rx5 as in the instructions, but to Serial4/UART4 (Tx/Rx4 - red circle, other side of board) due to a possible conflict with the SBUS communication option. I know Caleb has it working on his board, but this was suggested by ChatGPT.
Not sure why the Rpi is not working. Yes, I would try swapping Tx/Rx in case there was a board issue. I know it’s not fun resoldering, but it’s a possibility.
