YAW Drift on new Build
Hello again. I finally got everything assembled and I went through the initial setup and calibration. I took the drone outside to see if it would fly. It lifted pretty easily but it appears to be rotating clockwise. I double-checked the motor directions and to the best of my knowledge, they are spinning in the correct directions. Where should I start looking to troubleshoot this issue?
Newbie mistake here. I did not have the GPS module turned so the front was in the right place. Gonna do more testing but I am pretty sure that is the problem. Maybe leave this here in case somebody else gets hasty and makes the same mistake.
Were you in Guided or Loiter mode? Would like to have seen if it stopped in Stabilize mode, which does not use GPS.
https://ardupilot.org/copter/docs/flight-modes.html
“Toilet-bowling” can occur also due to improper calibration or environmental EM interference.
It was in Stabilize but I had also gotten the trim messed up. It is flying pretty stable now in all modes. I think I just got a little excited to see it fly after building it for a while in my spare time and got in a hurry at the end. I had a pretty limited area in my front yard today but I am going to take it to a larger area tomorrow. Everything is looking pretty good at this point I just need to learn more and practice more!
@jax200 10 points
closed #6
