Hello Jack, Christian and anyone who needs help in this step for building your drone! You won’t need a keyboard or monitor for the RPi
- Download and Flash OS Image to SD card
a. Insert the SD card in the usb reader and insert the usb reader to your computer.
b. Download Raspberry Pi OS Lite (2021-01-11-raspios-buster-armhf-lite.zip).
c. Extract the Raspberry Pi OS Lite zip file in a folder.
d. Download and install Etcher (Etcher-Setup-1.5.116.exe).
e. Open Etcher, select the image where you extracted the Raspberry Pi OS Lite zip file.
f. Flash the OS into SD card.
g. Remove and insert the SD card back again.
Note: Raspberry Pi OS Lite is the Raspberry Pi Operating System. Etcher is used to flash the operating system into the SD card.
- Configure RPi to connect to the internet
a. Download and install Advanced IP Scanner (Advanced_IP_Scanner_2.5.3850.exe).
b. Download and install Putty (putty-64bit-0.74-installer.exe).
c. Download and install Notepad++ (npp.7.9.3.Installer.exe).
d. Create a text file named wpa_supplicant.conf. (Remove .txt extension if any.)
e. Use Notepad++ to open wpa_supplicant.conf which is in the SD card.
f. Copy and paste the following:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=<Insert 2 letter ISO 3166-1 country code here>
network={
ssid=“Name of your wireless LAN”;
psk=“Password for your wireless LAN”;
g. country = US if you live in the US.
h. Edit with your wifi name and password.
i. Save the file.
j. Create a new txt file named ssh and remove the .txt extension.
Note: Advanced IP scanner is used to help us find the random IP address assigned to RPi when the RPi connects to the internet. Putty is used to secure shell (SSH) or remotely access the raspberry pi by using the IP address. Notepad++ is used to access certain files in the SD card.
- SSH into RPi
a. Insert the SD card into the metal slot of RPi.
b. Power the RPi. Wait for 90 seconds up to 2 minutes.
c. Launch Putty and type raspberrypi for host name. Port should be 22.
d. Click open. Login as pi. Password is raspberry.
You should be able to remotely access the raspberry pi now. RPi is connected to the internet.
Note: To power the RPi you can use a micro usb C cord or connect it to the power distribution of the drone. The RPi can turn on a yellow light indicating that it is setting up something and it is not ready yet to be logged or used. A solid blinking red light means that the RPi is ready to be SSHed.
I hope this helps!
