I’ve been trying to find a solution to view gps data from the rpi cli.
Does the pixhawk have a output file? I found something about GPS_Dump but I don’t think it’s on the 2.4.8 pix.
Can I monitor a serial port for this?
Check the tlog file for gps data. You can use MP or offline tools to view.
https://ardupilot.org/mavproxy/docs/analysis/mavtools.html
https://ardupilot.org/copter/docs/common-mission-planner-telemetry-logs.html
For real-time monitoring you can see position data with mavproxy commands using
status GLOBAL_POSITION_INT
I wasn’t able to figure out how to extract just lat or lon data from this dictionary, but if you do perhaps you could use the graph module to output it real-time.
You can also monitor output with Mission Planner, python or mavlink code.
With python you could set up a socket to monitor data sent to a laptop. You would create a vehicle object and use something like
lat = vehicle.location.global_frame.lat
which you could store, print or send.
A mavlink example might include
from pymavlink import mavutil
#Start a connection listening to a UDP port
vehicle = mavutil.mavlink_connection(‘udpin:localhost:14551’)
#Wait for the first heartbeat
#This sets the system and component ID of remote system for the linkvehicle.wait_heartbeat()
print(“Heartbeat from system (system %u component %u)” % (vehicle.target_system, vehicle.target_component))
while 1:
msg = vehicle.recv_match(type=‘GLOBAL_POSITION_INT’,blocking=True)
print(msg)
I have also taken GPS csv data and later plotted it on Google Earth as a kml file.
In case anyone was trying to parse lat long:
lat = vehicle.field('GLOBAL_POSITION_INT', 'lat', 0) * 1.0e-7
lon = vehicle.field('GLOBAL_POSITION_INT', 'lon', 0) * 1.0e-7
print(lat)
print(lon)
