Weight estimating spreadsheet
I think I saw a utility in the programming course for something similar for drone building for adding up weights. I know it is simple, but is yours something that can be shared?
Sure, that is no problem @CarlRossi !
Here is a link to a copy of the Weight and TWR Calculator sheet.
https://docs.google.com/spreadsheets/d/1bCXjyHeDOYkMv3jZK8B4VABcV8b7ZKPE8ylR34jI-7E/edit?usp=sharing
You can either use that sheet directly or copy the contents into your own sheet.
Hope that helps!
