Taco Delivery Script Error
Attempting to run my taco_delivery.py script, and keep getting this error message:
** File “/home/joseph/catkin_ws/src/gazebo_drone/scripts/taco_delivery.py”, line 278, in **
** goto(wp_taco)**
** File “/home/joseph/catkin_ws/src/gazebo_drone/scripts/taco_delivery.py”, line 71, in goto**
** distanceToTargetLocation = get_distance_meters(targetLocation,vehicle.location.global_relative_frame)**
** File “/home/joseph/catkin_ws/src/gazebo_drone/scripts/taco_delivery.py”, line 65, in get_distance_meters**
** dLat=targetLocation.lat - currentLocation.lat**
AttributeError: ‘tuple’ object has no attribute 'lat’
taco_delivery.py code below:
#!/usr/bin/python
#######IMPORTS########
import rospy
import cv2
import cv2.aruco as aruco
import sys
import numpy as np
import ros_numpy as rnp
from dronekit import connect, VehicleMode, LocationGlobalRelative, LocationGlobal
from pymavlink import mavutil
from array import array
#######VARIABLES
vehicle = connect(‘udp:127.0.0.1:14551’,wait_ready=True)
vehicle.parameters[‘PLND_ENABLED’]=1
vehicle.parameters[‘PLND_TYPE’]=1
vehicle.parameters[‘PLND_EST_TYPE’]=0
vehicle.parameters[‘LAND_SPEED’]=20 #cm/s
velocity=.5 ###m/s #
takeoff_height=9 ##meters#
newimg_pub = rospy.Publisher(’/webcam/image_new’, Image, queue_size=10)
ids_to_find = [129,72]
marker_sizes = [40,20]
marker_heights = [10,4]
horizontal_res = 640
vertical_res = 480
horizontal_fov = 62.2 * (math.pi / 180) ##62.2 for picam V2, 53.5 for V1
vertical_fov = 48.8 * (math.pi / 180) ##48.8 for V2, 41.41 for V1
found_count=0
notfound_count=0
#########CAMERA INTRINSICS#######
camera_matrix = [[530.8269276712998, 0.0 ,320.5], [0.0, 530.8269276712998, 240.5], [0.0, 0.0, 1.0]]
time_last=0
time_to_wait = .1 ##100 ms
time_to_sleep=5 #seconds to sit on ground after reaching waypoint
sub = ‘’ #initilialize subscriber variable to make it global
#########FUNCTIONS########
def get_distance_meters(targetLocation,currentLocation):
dLon=targetLocation.lon - currentLocation.lon
return math.sqrt((dLon*dLon)+(dLat*dLat))*1.113195e5
def goto(targetLocation):
vehicle.simple_goto(targetLocation)
while vehicle.mode.name=="GUIDED":
    currentDistance = get_distance_meters(targetLocation,vehicle.location.global_relative_frame)
    if currentDistance<distanceToTargetLocation*.02:
        print("Reached target waypoint")
        time.sleep(2)
return None
def arm_and_takeoff(targetHeight):
while vehicle.is_armable !=True:
print (‘Waiting for vehicle to become armable’)
print (‘Vehicle is now armable’)
vehicle.mode = VehicleMode('GUIDED')
while vehicle.mode !='GUIDED':
    print ('Waiting for drone to enter GUIDED flight mode')
print ('Vehicle now in GUIDED flight mode, have fun!')
vehicle.armed = True
while vehicle.armed==False:
    print ('Waiting for vehicle to become armed')
print ('Look out, virtual props are spinning!!!')
vehicle.simple_takeoff(targetHeight)
while True:
    print('Current Altitude %d'%vehicle.location.global_relative_frame.alt)
    if vehicle.location.global_relative_frame.alt >=.95*targetHeight:
print('Target altitude reached')
return None
def send_local_ned_velocity(vx,vy,vz):
0,
0,
0,
0b0000111111000111,
0,
0,
0,
vx,
vy,
vz,
0,0,0,0,0)
vehicle.send_mavlink(msg)
vehicle.flush()
def send_land_message(x,y):
msg = vehicle.message_factory.landing_target_encode(
0,
0,
x,
y,
0,0,0
vehicle.flush()
def msg_receiver(message):
global notfound_count, found_count, time_last, time_to_wait, id_to_find, sub
    np_data = rnp.numpify(message) ##Deserialize image data into array
    ids = ''
    (corners, ids, rejected) = aruco.detectMarkers(image=gray_img,dictionary=aruco_dict,parameters=parameters)
    ids ==[129,72]
    altitude = vehicle.location.global_relative_frame.alt ##meters
    id_to_find=0
    marker_height=0
    marker_size=0
    if altitude > marker_heights[1]:
        id_to_find=ids_to_find[0]
        marker_height=marker_heights[0]
        marker_size=marker_sizes[0]
    elif altitude < marker_heights[1]:
        id_to_find=ids_to_find[1]
        marker_height=marker_heights[1]
        marker_size=marker_sizes[1]
    ids_array_index=0
    found_id=0
    print("Looking for marker: "+ str(id_to_find))
    if vehiclemode!='LAND':
        vehicle.mode =VehicleMode('LAND')
        while vehicle.mode!='LAND':
        print("Vehicle is in land mode")
    if vehicle.armed==False:
        sub.unregister()
        return None
    try:
        if ids is not None:
            for id in ids:
                if ids[0]==id_to_find:
                    corners_single=[corners[ids_array_index]]
                    corners_single_np =np.asarray(corners_single)
                    ret = aruco.estimatePoseSingleMarkers(corners_single,marker_size,cameraMatrix=np_camera_matrix,distCoeffs=np_dist_coeff)
                    (rvec, tvec) = (ret[0][0,0,:],ret[1][0,0,:])
                    x = '{:.2f}'.format(tvec[0]) ###Xerror/distance between camera and aruco in CM
                    y = '{:.2f}'.format(tvec[1]) ###Yerror/distance between camera and aruco is CM
                    z = '{:.2f}'.format(tvec[2]) ###Zerror/distance between camera and arco in CM
                    y_sum=0
                    x_sum=0
                    x_sum = corners_single_np[0][0][0][0] + corners_single_np[0][0][1][0] + corners_single_np[0][0][2][0] + corners_single_np[0][0][3][0]
                    y_sum = corners_single_np[0][0][0][1] + corners_single_np[0][0][1][1] + corners_single_np[0][0][2][1] + corners_single_np[0][0][3][1]
                    x_avg = x_sum / 4
                    y_avg = y_sum / 4
                    x_ang = (x_avg - horizontal_res*.5)*horizontal_fov/horizontal_res
                    y_ang = (y_avg - vertical_res*.5)*vertical_fov/vertical_res
                    if vehicle.mode !='LAND':
                        vehicle.mode = VehicleMode('LAND')
                        while vehicle.mode !='LAND':
                        print ('Vehicle in LAND mode')
                        send_land_message(x_ang,y_ang)
                    else:
                    marker_position = 'MARKER POSITION: x='+x+' y='+y+' z='+z
                    aruco.drawDetectedMarkers(np_data,corners)
                    aruco.drawAxis(np_data,np_camera_matrix,np_dist_coeff,rvec,tvec,10)
                    ##putText(image, text_to_draw, position,font_face,frontScale,color,thickness)
                    cv2.putText(np_data,marker_position,(10,50),0,.5,(255,0,0),thickness=2)
                    print(marker_position)
                    print('FOUND COUNT: '+str(found_count)+ ' NOTFOUND COUNT: '+str(notfound_count))
                    found_count = found_count + 1
                    found_id=1
                ids_array_index=ids_array_index+1
            if found_id==0:
                notfound_count=notfound_count + 1
        else:
    except Exception as e:
        print 'Target likely not found'
        print e
    new_msg = rnp.msgify(Image, np_data,encoding='rgb8')
    newimg_pub.publish(new_msg)
    time_last = time.time()
else:
    return None
def lander():
global sub
rospy.init_node(‘drone_node’, anonymous=False)
sub = rospy.Subscriber(’/webcam/image_raw’, Image, msg_receiver)
while vehicle.armed==True:
return None
if name==‘main’:
try:
#### record home coordinates of drone so we know where to fly back to
lat_home=vehicle.location.global_relative_frame.lat
lon_home=vehicle.location.global_relative_frame.lon
    wp_home=LocationGlobalRelative(lat_home,lon_home,takeoff_height)
    wp_taco=(-35.36303741, 149.1652374,takeoff_height)
    arm_and_takeoff(takeoff_height)
    ######Fly to waypoint
    goto(wp_taco)
    ##### Precision land on taco aruco
    lander()
    print("")
    print("--------")
    print("Arrived at the taco destination")
    print("Dropping tacos and heading home")
    print("----------ENJOY---------")
    time.sleep(time_to_sleep)
    ############Fly the drone back to the waypoint
    goto(wp_home)
    lander()
    print("")
    print("---------------")
    print("Made it back home for another delivery")
    print ("-----------")
    pass
Hi there
It looks like when you define your taco waypoint with variable " wp_taco" you didn’t input the coordinates into the LocationGlobalRelative function like you did with wp_home.
I think this will fix your issue
Works like a charm, thank you.
By the way, how exactly do you change the default home coordinates? In this script, I saw you were adding 25 meters from the home location for the wp_taco (-35.36303741, 149.1652374).
Great question, the location used by the sitl is configured in sim_vehicle.py or set to CMAC by default if not configured.
Line 863: group_sim.add_option("-L", “–location”, type=‘string’, default=‘CMAC’, help=“select start location from Tools/autotest/locations.txt”)
In the same folder as sim_vehicle.py (apm/ardupilot/Tools/autotest) you can find the locations.txt file, which contains location settings by name/ICAO; #NAME=latitude,longitude,absolute-altitude,heading.
If you scan through the file you should find CMAC=-35.363261,149.165230,584,353
So in your simulation if you wanted to use a different location, add the --location option to the end of your sim_vehicle.py call, for example: …/Tools/autotest/sim_vehicle.py -f gazebo-iris --console --location LGAT --map
That will start the simulation home to LGAT.
Excellent, thanks @PhotonJon
closed #6
@PhotonJon 10 points
@caleberg 5 points
