stm_vehicle.py
stm_vehicle.py: command not found
Stm_vehicle.py stm_vehicle.py: command not found
mnaeem87
In which directory are you running this? It will work in ArduCopter
(or others as per your requirement). If you want to run it from Tools/autotools
, then you must specify the vehicle type e.g. -v ArduCopter
But if your intention is to view/edit it from Tools/autotools
, you can either use sudo vi
or gedit
. In another directory where sim_vehicle does not exist, it will create a new file with this name which is of no use as it will be all blank.
