Hi!
I do not know why the stl drone do not land on the aruco marker.
#!/usr/bin/env python
########import#########
import rospy
import cv2
import cv2.aruco as aruco
import sys
import numpy as np
import ros_numpy as rnp
from dronekit import connect, VehicleMode, LocationGlobalRelative, LocationGlobal
from pymavlink import mavutil
from array import array
#######variable########
vehicle = connect(‘udp:127.0.0.1:14551’,wait_ready=True)
vehicle.parameters[‘PLND_ENABLED’]=1
vehicle.parameters[‘PLND_TYPE’]=1
vehicle.parameters[‘PLND_EST_TYPE’]=0
vehicle.parameters[‘LAND_SPEED’]=30 ##cms/s
velocity=-.5 #m/s
takeoff_height=4 #m
newimg_pub = rospy.Publisher(’/camera/color/image_new’, Image, queue_size=10)
id_to_find = 72 ##arucoID
marker_size = 20 ##CM
horizontal_res = 640
vertical_res = 480
horizontal_fov = 62.2 * (math.pi / 180) ##62.2 for picam V2, 53.5 for V1
vertical_fov = 48.8 * (math.pi / 180) ##48.8 for V2, 41.41 for V1
found_count=0
notfound_count=0
#############CAMERA INTRINSICS#######
camera_matrix = [[530.8269276712998, 0.0, 320.5],[0.0, 530.8269276712998, 240.5],[0.0, 0.0, 1.0]]
time_last=0
time_to_wait = .1 ##100 ms
################FUNCTIONS###############
def arm_and_takeoff(targetHeight):
while vehicle.is_armable !=True:
print(‘Waiting for vehicle to become armable’)
print(‘Vehicle is now armable’)
vehicle.mode = VehicleMode('GUIDED')
while vehicle.mode !='GUIDED':
print('Waiting for drone to enter GUIDED flight mode')
print('Vehicle now in GUIDED mode. Have Fun!')
vehicle.armed = True
while vehicle.armed ==False:
print('Waiting for vehicle to become armed.')
print('Look out! Virtual props are spinning!')
vehicle.simple_takeoff(targetHeight)
while True:
print('Current Altitude: %d'%vehicle.location.global_relative_frame.alt)
if vehicle.location.global_relative_frame.alt >=.95*targetHeight:
print('Target altitude reached!')
return None
##Send velocity command to drone
def send_local_ned_velocity(vx,vy,vz):
0,
0,
0,
0b0000111111000111,
0,
0,
0,
vx,
vy,
vz,
0,0,0,0,0)
vehicle.send_mavlink(msg)
vehicle.flush()
####responsible for precision landing
def send_land_message(x,y):
msg = vehicle.message_factory.landing_target_encode(
0,
0,
x,
y,
0,0,0
vehicle.flush()
def msg_receiver(message):
np_data = rnp.numpify(message) ##Deserialize image data into array
ids = ''
(corners, ids, rejected) = aruco.detectMarkers(image=gray_img,dictionary=aruco_dict,parameters=parameters)
try:
if ids is not None:
if ids[0]==id_to_find:
ret = aruco.estimatePoseSingleMarkers(corners,marker_size,cameraMatrix=np_camera_matrix,distCoeffs=np_dist_coeff)
(rvec, tvec) = (ret[0][0,0,:],ret[1][0,0,:])
x = '{:.2f}'.format(tvec[0]) ### Xerror/distance between camera and aruco in CM
y = '{:.2f}'.format(tvec[1]) ### Yerror/distance between camera and aruco in CM
z = '{:.2f}'.format(tvec[2]) ### Zerror/distance between camera and aruco in CM
y_sum=0
x_sum=0
x_sum = corners[0][0][0][0] + corners[0][0][1][0] + corners[0][0][2][0] +corners[0][0][3][0]
y_sum = corners[0][0][0][1] + corners[0][0][1][1] + corners[0][0][2][1] +corners[0][0][3][1]
x_avg = x_sum / 4
y_avg = y_sum / 4
x_ang = (x_avg - horizontal_res*.5)*horizontal_fov/horizontal_res
y_ang = (y_avg - vertical_res*.5)*vertical_fov/vertical_res
if vehicle.mode !='LAND':
vehicle.mode = VehicleMode('LAND')
while vehicle.mode !='LAND':
print('Vehicle in LAND mode')
send_land_message(x_ang,y_ang)
else:
marker_position = 'MARKER POSITION: x='+x+' y='+y+' z='+z
aruco.drawDetectedMarkers(np_data,corners)
aruco.drawAxis(np_data,np_camera_matrix,np_dist_coeff,rvec,tvec,10)
##putText(image, text_to_draw,position,font_face,fontScale,color,thickness)
cv2.putText(np_data,marker_position,(10,50),0,.7,(255,0,0),thickness=2)
print(marker_position)
print('FOUND COUNT: '+str(found_count)+ ' NOTFOUND COUNT: '+str(notfound_count))
found_count = found_count + 1
else:
else:
except Exception as e:
print('Target likely not found')
print(e)
new_msg = rnp.msgify(Image, np_data,encoding='rgb8')
newimg_pub.publish(new_msg)
time_last = time.time()
else:
return None
def subscriber():
rospy.init_node(‘drone_node’,anonymous=False)
sub = rospy.Subscriber(’/camera/color/image_raw’, Image, msg_receiver)
rospy.spin()
if name==‘main’:
try:
arm_and_takeoff(takeoff_height)
send_local_ned_velocity(velocity,0,0)
time.sleep(5)
subscriber()
pass
