SITL Drone Introduction Video
Hello Experts,
I’d been following the video list in the drone programming course SITL Drone Introduction video(Simulated Computer drone) when something I could not figure out why the console window and the map widow did not appear after compiling the arducopter firmware from the command sim_vehicle.py --map --console.
Checkout my full screen desktop screenshot missing console & map window. I hope anyone can help.
-cecil
“ImportError: No module named wx”
try locate wx_loader.py
might have to re-install mavproxy?
jack
Just like you said, I found the file wx_loader.py in my specified directory. From that point, what shall I do next? So I just assume the file exist so, I goto next step…
Reinstall MAVProxy1.6.2, try the command again: sim_vehicle.py --map --console but still the same- No map, No console.
Then I upgrade it by typing command pip install --upgrade pip - same problem.
Do you have another solution? Thanks for helping…
I just took this course as well, so no expert… But I have been successfully running the bash scripts.
Caleb warns in the video not to upgrade pip, as it might cause problems.
After installing mavproxy, did you run:
sudo usermod -a -G dialout $USER
sudo apt remove modemanager
If I encountered this issue, frankly I would reinstall everything starting with ubuntu. There are a number of steps where a slight mistake could mess you up.
Make sure you have entered all the required dependencies.
As a side note, the video didn’t include the screen dependency, which is needed for the bash commands.
I post this question to this link, cause it relates to the SITL Drone Introduction Video.
I’m able to launch the sim_vehicle.py file with --map and --console options.
My problem is that I’m not able to see the “view” menu to select a map and therefore not drone neither map appear.
Help to solve this issue is appreciated as I’m not able to progress without seeing the map.
Thanks in advance for your help!
Sorry for the above message.
I’ve managed to solve the problem myself. I’ve seen that the view menu appears attached to the console tab, so no problem any more
Kind regards,
Pablo
I was wondering if anyone ended up solving this? I’m halfway through 2020 and having this issue as well as my map and console are not showing up.
I just tried installing the pre-configured package from Caleb and all good. I assume then you instead tried to build it yourself per the lecture? Remembered to not upgrade pip? What versions pip, ubuntu, MAVProxy, Copter and python are installed? Could you provide a screenshot of your command and resulting messages?
