Should the air module telemetry module have a flashing light when it's powered?
Should the air module telemetry module have a flashing light on it when it’s plugged in?
Thanks.
The USB side on my laptop flashes green with a quick red flash. (This just stopped after a while, it still flashes green.)
On windows, I got the right driver installed and using MP, I got these details on the USB computer side, and I’m unable to communicate with the drone side…
Is there a way to reset the air side? Or set a key or something?
The LED flashing you describe is normal. Depending on what radios you are using, instructions are available here:
https://ardupilot.org/copter/docs/common-configuring-a-telemetry-radio-using-mission-planner.html
https://ardupilot.org/copter/docs/common-3dr-radio-advanced-configuration-and-technical-information.html
Some very cheap radios might be problematic and might require reloading the firmware after re-setting the boot loader. This can (sometimes) be done following this method:
