Raspberry Pi versions
So I’m currently trying to implement the precision landing system in real life after completing the simulations
I would just like to ask which Raspberry Pi OS(Rpi OS or Ubuntu?)and versions are recommended?
My current Raspberry Pi 4 runs Rpi OS and the python version is 3.9.2
I believe you can do it with either. I did run it in the field with RPi OS but with python 2 (original course). Since then I have migrated over to python3 using ROS Noetic on the SITL. It should work in the field as well.
May I ask specifically which RPi OS or RPi OS lite version did you use that comes with Python 2 as default?
Linux 10 (Buster)
thank you
closed #6
