I have hooked up the tf mini plus rangefinder to the pix hawks Serial 4/5. The wiring is all correct and I have done all the correct full parameter tree changes. When I hook it up to ArduPilot im getting PreArm:rangefinder 1 was not detected ardupilot. Cant seem to find what’s wrong. Thank you
Rangefinder not detected
jax200
You might want to download the latest firmware and test with the GUI from the Benewake website:
I once had an older version that didn’t work until I updated the fm. You could also post or send me the parameters to double check.
llorenzo313
Hey Jax thank you. Im having a hard time finding the application to update the firmware from that link. Do you know which one I should download? Thank you
jax200
Check this for upgrade info. You might need to contact them.
https://github.com/TFmini/TFmini-Plus
Last time I checked the file was called “TFminiPlus Upgrade Tool.exe”
