I have downloaded QGround Control but it is notifying me to calibrate the drone. I’m using SITL and didn’t see this in the instructions. Not sure what I did wrong, has anyone else had this happen?
QGround Control Requiring Calibration
caleberg
Hi there @z99
Are you following the Drone Programming Primer curriculum, or are you independently attempting to connect QGC with SITL?
What version or ArduCopter are you using?
Is this prompt preventing you from running the SITL drone? This is definitely not normal behavior for SITL, I’m wondering if a newer version of the ArduCopter software (above 4.0.3) had some issues related to it? My guess is if you went down to a less new version the calibration prompt would go away.
