Hello,
the nuts on my propellers keep loosening when spinning, sometimes even after simple test missions that involve only hovering for a few seconds.
When looking at the front of the drone, the black nut is right and the silver one (red in the course videos) is left. On the back rotors, it’s the other way round. So, essentially, the tightening direction of every nut is opposed to the motor’s spin direction.
I’m currently using these replacement propellers, but I had the same problem with the original ones. I’m using the adapter rings that come with the propellers to better conform them to the motor shafts.
Currently, I handle the problem with Loctite, but that surely isn’t what the motor constructors intended.
I can’t even explain the problem. The spinning should only lead to the nuts tightening even closer…
Thanks in advance
