Precision landing single aruco
Hey guys so the precision_landing_single_aruco.py script goes great. The only problem I have is the drone takes off into the air too fast. I want to be able to slow down the takeoff part of the script. Here is my code. Thank you.
###########DEPENDENCIES################
import socket
import exceptions
import argparse
from dronekit import connect, VehicleMode,LocationGlobalRelative,APIException
from pymavlink import mavutil
from imutils.video import WebcamVideoStream
import cv2
import cv2.aruco as aruco
import numpy as np
import imutils
#######VARIABLES####################
##Aruco
id_to_find = 72
marker_size = 20.5 #cm
takeoff_height = 6
velocity = .3
##Camera
horizontal_res = 640
vertical_res = 480
cap = WebcamVideoStream(src=0, width=horizontal_res, height=vertical_res).start()
horizontal_fov = 62.2 * (math.pi / 180 ) ##Pi cam V1: 53.5 V2: 62.2
vertical_fov = 48.8 * (math.pi / 180) ##Pi cam V1: 41.41 V2: 48.8
calib_path="/home/pi/video2calibration/calibrationFiles/"
cameraMatrix = np.loadtxt(calib_path+‘cameraMatrix.txt’, delimiter=’,’)
cameraDistortion = np.loadtxt(calib_path+‘cameraDistortion.txt’, delimiter=’,’)
##Counters and script triggers
found_count=0
notfound_count=0
first_run=0 #Used to set initial time of function to determine FPS
start_time=0
end_time=0
script_mode = 1 ##1 for arm and takeoff, 2 for manual LOITER to GUIDED land
ready_to_land=0 ##1 to trigger landing
manualArm=True ##If True, arming from RC controller, If False, arming from this script.
#########FUNCTIONS#################
def connectMyCopter():
parser = argparse.ArgumentParser(description='commands')
parser.add_argument('--connect')
args = parser.parse_args()
connection_string = args.connect
baud_rate = 57600
vehicle = connect(connection_string,baud=baud_rate, wait_ready=True)
return vehicle
def arm_and_takeoff(targetHeight):
while vehicle.is_armable!=True:
print(“Waiting for vehicle to become armable.”)
print(“Vehicle is now armable”)
vehicle.mode = VehicleMode("GUIDED")
while vehicle.mode!='GUIDED':
	print("Waiting for drone to enter GUIDED flight mode")
print("Vehicle now in GUIDED MODE. Have fun!!")
    if manualArm==False:
        vehicle.armed = True
        while vehicle.armed==False:
            print("Waiting for vehicle to become armed.")
    else:
        if vehicle.armed == True:
            print("Exiting script. manualArm set to True but vehicle not armed.")
            print("Set manualArm to True if desiring script to arm the drone.")
            return None
    print("Look out! Props are spinning!!")
vehicle.simple_takeoff(targetHeight) ##meters
while True:
	print("Current Altitude: %d"%vehicle.location.global_relative_frame.alt)
	if vehicle.location.global_relative_frame.alt>=.95*targetHeight:
print("Target altitude reached!!")
return None
def send_local_ned_velocity(vx, vy, vz):
0,
0, 0,
0b0000111111000111,
0, 0, 0,
vx, vy, vz,
0, 0, 0,
0, 0)
vehicle.send_mavlink(msg)
vehicle.flush()
def send_land_message(x,y):
msg = vehicle.message_factory.landing_target_encode(
0,
0,
x,
y,
0,
0,
0,)
vehicle.flush()
def lander():
global first_run,notfound_count,found_count,marker_size,start_time
if first_run==0:
print(“First run of lander!!”)
first_run=1
start_time=time.time()
frame = cap.read()
frame = cv2.resize(frame,(horizontal_res,vertical_res))
frame_np = np.array(frame)
gray_img = cv2.cvtColor(frame_np,cv2.COLOR_BGR2GRAY)
ids=''
corners, ids, rejected = aruco.detectMarkers(image=gray_img,dictionary=aruco_dict,parameters=parameters)
if vehicle.mode!='LAND':
    vehicle.mode=VehicleMode("LAND")
    while vehicle.mode!='LAND':
        print('WAITING FOR DRONE TO ENTER LAND MODE')
try:
    if ids is not None and ids[0] == id_to_find:
        ret = aruco.estimatePoseSingleMarkers(corners,marker_size,cameraMatrix=cameraMatrix,distCoeffs=cameraDistortion)
        (rvec, tvec) = (ret[0][0, 0, :], ret[1][0, 0, :])
        x = '{:.2f}'.format(tvec[0])
        y = '{:.2f}'.format(tvec[1])
        z = '{:.2f}'.format(tvec[2])
        y_sum = 0
        x_sum = 0
        x_sum = corners[0][0][0][0]+ corners[0][0][1][0]+ corners[0][0][2][0]+ corners[0][0][3][0]
        y_sum = corners[0][0][0][1]+ corners[0][0][1][1]+ corners[0][0][2][1]+ corners[0][0][3][1]
        x_avg = x_sum*.25
        y_avg = y_sum*.25
        x_ang = (x_avg - horizontal_res*.5)*(horizontal_fov/horizontal_res)
        y_ang = (y_avg - vertical_res*.5)*(vertical_fov/vertical_res)
            vehicle.mode = VehicleMode('LAND')
            print("------------------------")
            print("Vehicle now in LAND mode")
            send_land_message(x_ang,y_ang)
        else:
            pass
        print("X CENTER PIXEL: "+str(x_avg)+" Y CENTER PIXEL: "+str(y_avg))
        print("FOUND COUNT: "+str(found_count)+" NOTFOUND COUNT: "+str(notfound_count))
        print("MARKER POSITION: x=" +x+" y= "+y+" z="+z)
        found_count=found_count+1
        print("")
    else:
except Exception as e:
    print('Target likely not found. Error: '+str(e))
#######################MAIN###########################
vehicle = connectMyCopter()
##SETUP PARAMETERS TO ENABLE PRECISION LANDING
vehicle.parameters[‘PLND_ENABLED’] = 1
vehicle.parameters[‘PLND_TYPE’] = 1 ##1 for companion computer
vehicle.parameters[‘PLND_EST_TYPE’] = 0 ##0 for raw sensor, 1 for kalman filter pos estimation
vehicle.parameters[‘LAND_SPEED’] = 20 ##Descent speed of 30cm/s
if script_mode ==1:
arm_and_takeoff(takeoff_height)
print(str(time.time()))
#send_local_ned_velocity(velocity,velocity,0) ##Offset drone from target
ready_to_land=1
elif script_mode==2:
while vehicle.mode!=‘GUIDED’:
print(“Waiting for manual change from mode “+str(vehicle.mode)+” to GUIDED”)
ready_to_land=1
if ready_to_land==1:
while vehicle.armed==True:
lander()
end_time=time.time()
total_time=end_time-start_time
total_time=abs(int(total_time))
total_count=found_count+notfound_count
freq_lander=total_count/total_time
print("Total iterations: "+str(total_count))
print("Total seconds: "+str(total_time))
print("------------------")
print("lander function had frequency of: "+str(freq_lander))
print("Vehicle has landed")
Hey Jax, that’s what I thought. I even changed it to .1 didn’t do anything. It was at .5.
It clearly is used here and I tried changing it myself in gazebo but also no luck.
btw, velocity should be a negative value for takeoff per the NED convention.
Hey Jax, ok thank you. So instead of Velocity=.3 it should be Velocity=-.3?
Yes that is correct.
I believe you can also change the parameter WPNAV_ACCEL_Z to a lower value if the drone accelerates into the air too quick. This controls z-axis acceleration in autonomous modes.
10 points @jax200
