Precision Drone landing simulation alignment problem
So, I have managed to make the drone recognize the aruco marker, slowly descend on the ground, but it doesn’t align with the target. I assume that it has something to do with the parameters and maybe something is not properly installed. The changes I have made are a different size of marker, and a different dictionary, but it is recognized by the drone.
Here is the code:
#!/usr/bin/python
IMPORTS
import rospy
import cv2
import cv2.aruco as aruco
import sys
import numpy as np
import ros_numpy as rnp
from dronekit import connect, VehicleMode, LocationGlobalRelative, LocationGlobal
from pymavlink import mavutil
from array import array
VARIABLES
vehicle = connect(‘127.0.0.1:14550’,wait_ready=True)
vehicle.parameters[‘PLND_ENABLED’]=1
vehicle.parameters[‘PLND_TYPE’]=1
vehicle.parameters[‘PLND_EST_TYPE’]=0
vehicle.parameters[‘LAND_SPEED’]=30
velocity=-.5
takeoff_height=10
newimg_pub = rospy.Publisher(’/webcam/image_new’, Image, queue_size=10)
id_to_find = 17
marker_size = 50
aruco_dict = aruco.getPredefinedDictionary(aruco.DICT_5X5_250)
horizontal_res = 640
vertical_res = 480
horizontal_fov = 62.2 * (math.pi / 180)
vertical_fov = 48.8 * (math.pi / 180)
found_count = 0
notfound_count = 0
CAMERA INTRINSICS
camera_matrix = [[554.254691191187, 0.0, 320.5],[0.0, 554.254691191187, 240.5],[0.0, 0.0, 1.0]]
time_last = 0
time_to_wait = .1 ##100 ms
FUNCTIONS
def arm_and_takeoff(targetHeight):
while vehicle.is_armable !=True:
print(‘Waiting for vehicle to become armable’)
print(‘Vehicle is now armable’)
vehicle.mode = VehicleMode('GUIDED')
while vehicle.mode!='GUIDED':
    print('Waiting for drone to enter GUIDED flight mode')
print('Vehicle now in GUIDED mode. Have Fun!')
vehicle.armed = True
while vehicle.armed == False:
    print('Waiting for vehicle to become armed.')
print('Look out! Virtual props are spinning!')
vehicle.simple_takeoff(targetHeight)
while True:
    print('Current Altitude: %d'%vehicle.location.global_relative_frame.alt)
    if vehicle.location.global_relative_frame.alt >=.95*targetHeight:
print('Target altitude reached!')
return None
##Send velocity command to drone
def send_local_ned_velocity(vx, vy, vz):
0,
0,
0,
0b0000111111000111,
0,
0,
0,
vx,
vy,
vz,
0,0,0,0,0
vehicle.send_mavlink(msg)
vehicle.flush()
def send_land_message(x,y):
msg = vehicle.message_factory.landing_target_encode(
0,
0,
x,
y,
0,0,0
vehicle.flush()
def msg_receiver(message):
    np_data = rnp.numpify(message)
    ids = ''
    (corners, ids, rejected) = aruco.detectMarkers(image=gray_img, dictionary=aruco_dict, parameters=parameters)
    try:
        if ids is not None:
            if ids[0] == id_to_find:
                ret = aruco.estimatePoseSingleMarkers(corners, marker_size, cameraMatrix=np_camera_matrix, distCoeffs=np_dist_coeff)
                (rvec, tvec) = (ret[0][0,0,:],ret[1][0,0,:])
                x = '{:.2f}'.format(tvec[0])
                y = '{:.2f}'.format(tvec[1])
                z = '{:.2f}'.format(tvec[2])
                y_sum=0
                x_sum=0
                x_sum = corners[0][0][0][0] + corners[0][0][1][0] + corners[0][0][2][0] + corners[0][0][3][0]
                y_sum = corners[0][0][0][1] + corners[0][0][1][1] + corners[0][0][2][1] + corners[0][0][3][1]
                x_avg = x_sum / 4
                y_avg = y_sum / 4
                x_ang = (x_avg - horizontal_res*.5)*horizontal_fov/horizontal_res
                y_ang = (y_avg - vertical_res*.5)*vertical_fov/vertical_res
                print('x_ang = ' + str(x_ang))
                print('y_ang = ' + str(y_ang))
                if vehicle.mode != 'LAND':
                    vehicle.mode = VehicleMode('LAND')
                    while vehicle.mode !='LAND':
                    print('Vehicle in LAND mode')
                    send_land_message(x_ang, y_ang)
                else:
                marker_position = 'MARKER POSITION: x = ' + x + ' y = ' + y + ' z = ' + z
                aruco.drawDetectedMarkers(np_data, corners)
                aruco.drawAxis(np_data, np_camera_matrix, np_dist_coeff, rvec, tvec, 10)
                cv2.putText(np_data, marker_position, (10, 50), 0, .5, (255, 0, 0), thickness = 1)
                print(marker_position)
                print('FOUND COUNT: ' + str(found_count) + ' NOTFOUND COUNT: ' + str(notfound_count))
                found_count = found_count + 1
            else:
                notfound_count = notfound_count + 1
        else:
    except Exception as e:
        print('Target likely not found')
        print(e)
    new_msg = rnp.msgify(Image, np_data, encoding='rgb8')
    newimg_pub.publish(new_msg)
    time_last = time.time()
else:
    return None
def subscriber():
rospy.init_node(‘drone_node’, anonymous=False)
sub = rospy.Subscriber(’/webcam/image_raw’, Image, msg_receiver)
rospy.spin()
if name==‘main’:
try:
arm_and_takeoff(takeoff_height)
send_local_ned_velocity(velocity, 0, 0)
subscriber()
pass
and a picture of the enviroment:
What do you suggest changing to make it work?
What does ros topic show?
Remember to include a range finder for this to work.
closed #3
