When getting the drone to arm, I kept getting an error.
I had to connect to Mission Planner to get a readout on what the error was and it is showing up as:
PreArm: Battery 1 unhealthy (before attempting to arm the drone)
Arm: Battery 1 unhealthy (after attempting to move the left joystick to arm the drone)
Looking around on the net, it might have something to do with the battery failsafe settings.
I set it up for:
-Low Battery: 9.6
-Reserve mah: 750 (1/4 of 3000 mah)
I am using the Ovonic battery that came with the Pi-Drone kit. I also bought three more knowing that I want to flow a while when I go, but they are all stating the same error.
Iām unclear, what was the charge of the battery?
If the smoke stopper is still connected, then disconnect it. Only need it for initial testing of the sytem.
So I removed the smoke stopper and tested on three batteries.
The battās were charged to max with a smart charger (C240 Duo).
Went so far as to fully discharge and then charge.
What should the settings be in Mission Planner for a 3s 50c 3000mah 11.1v?
I have a feeling that the settings might be causing the issue and not the battās.
What are the correct āBattery Monitorā settings in MP SETUP/Optional Hardware/Battery Monitor?
Iāve tried a bunch of different settings and none of them seem to provide any battery information. Iām using the PiHawk drone and have built it as close as possible to the directions shown in the 21-Steps & Raspberry Pi drone courses.
I had to set the sensor to 3DR Power Module first, then I could change it to ā0: Otherā and calibrate based on what my external sensors were reading. If I tried to go straight to ā0: Otherā then every Measured battery voltage that I entered gave an error.
