I created a wpa_supplicant.conf file to connect with my Android hot spot, but for some reason the drone is not connecting. In fact, I can still ssh into it from my home network w/o the hot spot.
On another drone, using the same wpa_supplicant.conf file, it connects to the hot spot with no problem. As expected, I can no longer ssh into it from my home network w/o the hot spot. Curiously, if I examine the sd card from this drone on my PC, the wpa_supplicant.conf file I created is no longer visible.
So… what’s up and how to fix??
