I am not sure if the receiver is fine or not. The little LED on it never turns on. I hear continuous beeps but when I turn on the RC and try to bind it says ‘RX Binding’ but it never actually works.
The beeps are from the motors. Just to be sure, you first followed the Flysky FS-i6 Rx set up instructions, then the instructions for binding to the FS-X6B? You are using the correct cable from the port to the flight controller in the correct orientation? Then holding the RX bind button before you power up the flight controller? The red LED should be blinking. Then you hold the bind button of the TX, then power it up? The red LED will turn solid. Did you confirm the transmitter battery is fully charged? Did you try another Rx? I always have multiple units of receivers in case there is a problem with one.
X6B binding
Using PPM port
https://www.youtube.com/watch?v=q80QijmQzOI&ab_channel=TheDroneDojo
Using iBUS port
https://www.youtube.com/watch?v=tuPEIfN8ykM&ab_channel=ProjectBlueFalcon
FS-i6 setup
