Hi Everyone,
I started the course on how to build a Rpi drone because i’m interested in learning on every domains during all the parts of the process (i’m a Web developer).
I’m a French people, so the links regarding differents parts does not apply, and i’m building my own list to do so, but i have a few questions (i’m a beginner regarding electronics) :
- Is it possible to build a Rpi drone with a F330 frame ? if yes should the props be shorter? what will be different ?
- Regarding the battery, is possible to get one with high storage, for example 7000mha, but all of the high storages are used with 11V, so how to convert the output to be used with the Rpi (5v I guess) ?
- Is there a reference regarding the GPS mount ? because i’m not sure of what to get
- Regarding the battery charger there are differents numbers such as B6 50W or B6 80W and I cant’ figure out what’s the good one for this usage ?
Here I’m done with my first set of questions, I hope someone will have enough time and knowledge to help me a bit
Thank you everyone, have a good day
BR, Nicolas
