Git submodule update --init --recursive
git submodule update --init --recursive
Cloning into /home/abhisehk/courseRoot/apm/ardupilot/modules/ChibiOS’… fatal: unable to connect to github.com: github.com[0: 20.207.73.82]: errno=Connection timed out fatal: clone of ‘git://github.com/ArduPilot/ChibiOS.git’ into submodule path ‘/home/abhisehk/courseRoot/apm/ardupilot/modules/ChibiOS’ failed Failed to clone ‘modules/ChibiOS’. Retry scheduled Cloning into ‘/home/abhisehk/courseRoot/apm/ardupilot/modules/gbenchmark’…
Not sure but try searching a bit on the forum or internet. I found this that might help:
https://community.dojofordrones.com/t/how-to-incorporate-https-with-git-submodule-update-init-recursive/663
I was having the same issue. It has issues working with git but in my case everything was working fine when I manually downloaded these modules using HTTPS. However, when I came to actually simulate, it failed due to some reason. I opened port 9418 (if I remember correctly, the one for git) and a couple more, but nothing worked.
What worked in my case is the following sequence
  1. I started off working with an entirely new folder/directory
  2. I initialized these submodules during the download of the Ardupilot using the following command
    git clone --recurse-submodules https://github.com/AdruPilot/ardupilot
    It means download ArduPilot and initialize the submodules at the same time. Then carry on with the usual commands
    Moreover to visualize I am using QGC rather than the mission planner. I am working on Ubuntu 20.04
Below fix my error.
git config --global url.https://github.com/.insteadOf git://github.com/
