Can’t detect Aruco markers.
And land around the marker.
Please check below
#!/usr/bin/env python
######IMPORTS######
import rospy
import cv2
import cv2.aruco as aruco
import sys
import numpy as np
import ros_numpy as rnp
from dronekit import connect, VehicleMode, LocationGlobalRelative, LocationGlobal
from pymavlink import mavutil
from array import array
#####VARIABLES####
vehicle = connect(‘udp:127.0.0.1:14551’,wait_ready=True)
vehicle.parameters[‘PLND_ENABLED’]=1
vehicle.parameters[‘PLND_TYPE’]=1
vehicle.parameters[‘PLND_EST_TYPE’]=0
vehicle.parameters[‘LAND_SPEED’]=30 ##CM/S
velocity=.5 #m/s
takeoff_height=4 #m m0.5],[0.0, 530.8269276712998, 240.5],[0.0, 0.0, 1.0]]
newing_pub = rospy.Publisher(‘camera/color/image_new’, Image, queue_size=10)
id_to_find = 72 ##aruco
marker_size = 20 ## CM
horizontal_res = 640
vertical_res = 480
horizontal_fov = 62.2*(math.pi/180) ##62.2 for picam v2, 53.5 for v1
vertical_fov = 48.8*(math.pi/180) ##48.8 for v2, 41.41 for v1
found_count = 0
notfound_count = 0
#################[CAMERA_INTRINSICS]#################
camera_matrix = [[530.8269276712998, 0.0, 320.5],[0.0, 530.8269276712998, 240.5],[0.0, 0.0, 1.0]]
time_last = 0
time_to_wait = .1 ##100 ms
#####################FUNCTION########################
def arm_and_takeoff(targetHeight):
while vehicle.is_armable !=True:
print ‘Waiting for vehicle to become armable’
print ‘vehicle is now armable’
vehicle.mode = VehicleMode('GUIDED')
while vehicle.mode !='GUIDED':
print 'Waiting for drone to ender GUIDED flight mode'
print 'Vehicle now in GUIDED mode. Have Fun'
vehicle.armed = True
while vehicle.armed ==False:
print 'Waiting for vehicle to become armed.'
print 'Look out! Virtual props are spinning'
vehicle.simple_takeoff(targetHeight) ##meters
while True:
print('Current Altitude: %d'%vehicle.location.global_relative_frame.alt)
if vehicle.location.global_relative_frame.alt >=.95*targetHeight:
print 'Target altitude reached!'
return None
###SEND VELOCITY COMMAND TO DRONE###
def send_local_ned_velocity(vx,vy,vz):
0,
0, 0,
0b0000111111000111,
0, 0, 0,
vx, vy, vz,
0,0,0,0,0)
vehicle.send_mavlink(msg)
vehicle.flush()
def send_land_message(x,y):
msg = vehicle.message_factory.landing_target_encode(
0,
0,
x,
y,
0,
0,
0,)
vehicle.flush()
def msg_receiver(message):
np_data = rnp.numpify(message) ##Deserialize image data into array
ids = ''
#ids=[129,72]
(corners, ids, rejected) = aruco.detectMarkers(image=gray_img, dictionary=aruco_dict, parameters=parameters)
try:
if ids is not None:
if ids[0] == id_to_find:
ret = aruco.estimatePoseSingleMarkers(corners,marker_size, cameraMatrix=np_camera_matrix, distCoeffs=np_dist_coeff)
(rvec,tvec) = (ret[0][0,0,:],ret[1][0,0,:])
x='{:.2f}'.format(tvec[0]) ###Xerror/distance between camera and aruco in cm
y='{:.2f}'.format(tvec[1]) ###Yerror/distance between camera and aruco in cm
z='{:.2f}'.format(tvec[2]) ###Zerror/distance between camera and aruco in cm
x_sum=0
y_sum=0
x_sum = corners[0][0][0][0] + corners[0][0][1][0] + corners[0][0][2][0] + corners[0][0][3][0]
y_sum = corners[0][0][0][1] + corners[0][0][1][1] + corners[0][0][2][1] + corners[0][0][3][1]
x_avg = x_sum / 4
y_avg = y_sum / 4
x_ang = (x_avg - horizontal_res*.5)*horizontal_fov/horizontal_res
y_ang = (y_avg - vertical_res*.5)*vertical_fov/vertical_res
if vehicle.mode !='LAND':
vehicle.mode = VehicleMode('LAND')
while vehicle.mode !='LAND':
print 'Vehicle in LAND mode'
send_land_message(x_ang,y_ang)
else:
send_land_message(x_ang, y_ang)
marker_position = 'MARKER POSITION: x='+x+' y='+y+' z='+z
aruco.drawDetectedMarkers(np_data,corners)
aruco.drawAxis(np_data,np_camera_matrix,np_dist_coeff,rvec,tvec,10)
##puttText(image, text_to_draw,position,font_face,fontScale,color,thickness)
cv2.putText(np_data,marker_position,(10,50),0,.7,(255,0,0),thickness=2)
print(marker_position)
print ('FOUND COUNT: '+str(found_count)+ 'NOTFOUND COUNT: '+str(notfound_count))
found_count = found_count + 1
else:
else:
except Exception as e:
print 'Target likely not found'
print e
new_msg = rnp.msgify(Image, np_data,encoding='rgb8')
newing_pub.publish(new_msg)
time_last = time.time()
else:
return None
def subscriber():
rospy.init_node(‘drone_node’,anonymous=False)
sub = rospy.Subscriber(’/camera/color/image_raw’, Image, msg_receiver)
rospy.spin()
if name==‘main’:
try:
arm_and_takeoff(takeoff_height)
send_local_ned_velocity(velocity,0,0)
subscriber()
pass
