Hey guys im stuck on a problem im running the sitl precision landing script and evrything goes good until i run rosrun gazebo_drone gazebo_precision_landing.py vehicle arms takesoff then i get this error. Look over the script many times and cant find the solutuion. And under is my code. Thank you
vehicle is now armable
Waiting for drone to ender GUIDED mode
Vehicle now in GUIDED mode
Waiting for vehicle to become armed
Now Armed
Current Altitude: 0
Current Altitude: 0
Current Altitude: 0
Current Altitude: 0
Current Altitude: 2
Current Altitude: 3
Current Altitude: 3
Target altitude reached
File “/home/lorenzo/courseRoot/catkin_ws/src/gazebo_drone/scripts/gazebo_precision_landing.py”, line 201, in
send_local_ned_velocity(velocity,0,0)
NameError: name ‘send_local_ned_velocity’ is not defined
#!/usr/bin/python
###IMPORTS###
import rospy
import cv2
import cv2.aruco as aruco
import sys
import numpy as np
import ros_numpy as rnp
from dronekit import connect, VehicleMode, LocationGlobalRelative, LocationGlobal
from pymavlink import mavutil
from array import array
###VARIABLES###
vehicle = connect(‘udp:127.0.0.1:14551’,wait_ready=True)
vehicle.parameters[‘PLND_ENABLED’]=1
vehicle.parameters[‘PLND_TYPE’]=1
vehicle.parameters[‘PLND_EST_TYPE’]=0
vehicle.parameters[‘LAND_SPEED’]=30 ##CM/S
velocity=.5 #m/s
takeoff_height=4 #m
newimg_pub = rospy.Publisher(’/camera/color/image_new’, Image, queue_size=10)
id_to_find = 72 ##ARUCO ID
marker_size = 20 ##CM
horizontal_res = 640
vertical_res = 480
horizontal_fov = 62.2 * (math.pi / 180)
vertical_fov = 48.8 * (math.pi / 180)
found_count=0
notfound_count=0
###CAMERA INTRISICS##
camera_matrix = [[530.8269276712998, 0.0, 320.5],[0.0, 530.8269276712998, 240.5],[0.0, 0.0, 1.0]]
##TIME##
time_last=0
time_to_wait = .1 ##100ms
###FUNCTIONS###
def arm_and_takeoff(targetHeight):
while vehicle.is_armable !=True:
print ‘Waiting for vehicle to become armable’
print ‘vehicle is now armable’
vehicle.mode = VehicleMode('GUIDED')
while vehicle.mode !='GUIDED':
print 'Waiting for drone to ender GUIDED mode'
print 'Vehicle now in GUIDED mode'
vehicle.armed = True
while vehicle.armed ==False:
print 'Waiting for vehicle to become armed'
print('Now Armed')
vehicle.simple_takeoff(targetHeight)
while True:
print 'Current Altitude: %d'%vehicle.location.global_relative_frame.alt
if vehicle.location.global_relative_frame.alt >=.95*targetHeight:
print 'Target altitude reached'
return None
###SEND VELOCITY COMMAND TO DRONE###
def send_local_ned_velocity(vx,vy,vz):
0,
0,
0,
0b0000111111000111,
0,
0,
0,
vx,
vy,
vz,
0,0,0,0,0)
vehicle.send_mavlink(msg)
vehicle.flush()
def send_land_message(x,y):
msg = vehicle.message_factory.landing_target_encode(
0,
0,
x,
y,
0,0,0
vehicle.flush()
def msg_receiver(message):
np_data = rnp.numpify(message)
ids = ''
(corners, ids, rejected) = aruco.detectMarkers(image=gray_img,dictionary=aruco_dict,parameters=parameters)
try:
if ids is not None:
if ids[0]==id_to_find:
ret = aruco.estimatePoseSingleMarkers(corners,marker_size,cameraMatrix=np_camera_matrix,distCoeffs=np_dist_coeff)
(rvec, tvec) = (ret[0][0,0,:],ret[1][0,0,:])
x = '{:.2f}'.format(tvec[0]) ###Xerror/distance between camera and aruco in CM
y = '{:.2f}'.format(tvec[1]) ###Yerror/distance between camera and aruco in CM
z = '{:.2f}'.format(tvec[2]) ###Zerror/distance between camera and aruco in CM
y_sum=0
x_sum=0
x_sum = corners[0][0][0][0] + corners[0][0][1][0] + corners[0][0][2][0] + corners[0][0][3][0]
y_sum = corners[0][0][0][1] + corners[0][0][1][1] + corners[0][0][2][1] + corners[0][0][3][1]
x_avg = x_sum / 4
y_avg = y_sum / 4
x_ang = (x_avg - horizontal_res*.5)*horizontal_fov/horizontal_res
y_ang = (y_avg - vertical_res*.5)*vertical_fov/vertical_res
if vehicle.mode !='LAND':
vehicle.mode = VehicleMode('LAND')
while vehicle.mode !='LAND':
print 'Vehicle in LAND mode'
send_land_message(x_ang,y_ang)
else:
send_land_message(x_ang, y_ang)
marker_position = 'MARKER POSITION: x='+x+' y='+y+' z='+z
aruco.drawDetectedMarkers(np_data,corners)
aruco.drawAxis(np_data,np_camera_matrix,np_dist_coeff,rvec,tvec,10)
cv2.putText(np_data,marker_position,(10,50),0,.7,(255,0,0),thickness=2)
print(marker_position)
print ('FOUND COUNT: '+str(found_count)+ 'NOTFOUND COUNT: '+str(notfound_count))
found_count = found_count + 1
else:
else:
except Exception as e:
print 'Target likely not found'
print e
new_msg = rnp.msgify(Image, np_data,encoding='rgb8')
newimg_pub.publish(new_msg)
time_last = time.time()
else:
return None
def subscriber():
rospy.init_node(‘drone_node’,anonymous=False)
sub = rospy.Subscriber(’/camera/color/image_raw’, Image, msg_receiver)
rospy.spin()
if name==‘main’:
try:
arm_and_takeoff(takeoff_height)
subscriber()
pass
