dronekit.TimeoutError: wait_ready experienced a timeout after 30 seconds and WARNING: dronekit: Link timeout, no heartbeat in last 5 seconds ERROR When trying to connect 5 drones using com connection
import dronekit
from dronekit import connect, VehicleMode, LocationGlobalRelative
import dronekit_sitl
import argparse
import mathPreformatted text
import sys
import threading
import serial
from serial.tools.list_ports import comports
from serial.tools import hexlify_codec
from pymavlink import mavutil
db=[]
drone_sysids=[]
numberofsattelitesarray=[]
ports=[]
nn=[]
vehicleobjects=[]
vehicle_yaw=[]
distance=[]
# connectionstrings = ["COM6","COM8","COM16","COM17","COM14"]
def ask_for_port():
    sys.stderr.write('\n--- Available ports:\n')
    for n, (port, desc, hwid) in enumerate(sorted(comports()), 1):
        sys.stderr.write('--- {:2}: {}\n'.format(n, port))
        print(type(port))
        ports.append(port)
def connect_drones(num_drones):
    ask_for_port()
    for i in range(num_drones):
        vehicle = connect(ports[i],baud=57600,wait_ready=True,timeout=300,heartbeat_timeout=300)
        sattelitecount=vehicle.gps_0.satellites_visible;
        numberofsattelitesarray.append(sattelitecount)
        sysid=int(vehicle.parameters['SYSID_THISMAV'])
        vehicleobjects.append(vehicle);
        print("gps sattelites:",numberofsattelitesarray)
        print(vehicleobjects)
distance=[]
def distance_between_drones():
    for i in range(1,len(vehicleobjects)):
        v1 = vehicleobjects[0].location.global_relative_frame
        v2=vehicleobjects[i].location.global_relative_frame
        distance.append(distance_between_points(v1,v2))
    print(distance)
def check_distance():
    for i in range(len(distance)-1):
        if(distance[i+1]-distance[i]<4):
            print(distance[i+1]-distance[i])
            return False
    return True
# Function to get distance between two points
def distance_between_points(point1, point2):
    lat_difference = point2.lat - point1.lat
    lon_difference = point2.lon - point1.lon
    return math.sqrt((lat_difference * lat_difference) + (lon_difference * lon_difference)) * 1.113195e5
def arm_and_takeoff(i, altitude):
        if(check_satellites()==5 and check_distance()):
            while not vehicleobjects[i].is_armable:
                print(" Waiting for vehicle to initialise...")
                time.sleep(2)
            print("Arming motors")
            vehicleobjects[i].mode = VehicleMode("GUIDED")
            vehicleobjects[i].armed=True
            while not vehicleobjects[i].armed:
                print(" Waiting for arming...")
                time.sleep(3)
            print(vehicleobjects[i],i)
            vehicleobjects[i].airspeed = 5
            vehicleobjects[i].simple_takeoff(altitude)
        else:
            arm_and_takeoff(i,altitude)
def land():
    for i in range(len(vehicleobjects)):
        vehicleobjects[i].mode = VehicleMode("RTL")
        print("Land")
def close():  #this function will close vehicle object and shut down the simulator
    for drone in vehicleobjects:
        drone.close()
        print("Closed")
def check_satellites():
    noos=0
    for i in range(len(numberofsattelitesarray)):
        if numberofsattelitesarray[i]>=13:
            noos=noos+1
    return noos
connect_drones(5)
print("connection:",vehicleobjects)
for i in range(5):
    arm_and_takeoff(i,5)
for i in range(5):
    while True:
        print(" Altitude: ", vehicleobjects[i].location.global_relative_frame.alt)
        # Break and return from function just below target altitude.
        if vehicleobjects[i].location.global_relative_frame.alt >= 5 * 0.95:
            print("Reached target altitude")
print("Formation2")
# Move the drones to a new location.
# formstion2
# display details
formation2_alt=[5,6,7,6,5]
i=0
for vehicle in vehicleobjects:
    vehicle.simple_goto(LocationGlobalRelative(vehicle.location.global_relative_frame.lat,vehicle.location.global_relative_frame.lon,formation2_alt[i]))
    i=i+1
i=0
    while True:
        print(" Altitude: ", vehicle.location.global_relative_frame.alt)
        if vehicle.location.global_relative_frame.alt >= formation2_alt[i] * 0.95:
    i=i+1
print("Formation3")
# # formstion3
formation3_alt=[7,6,5,6,7]
i=0
    vehicle.simple_goto(LocationGlobalRelative(vehicle.location.global_relative_frame.lat,vehicle.location.global_relative_frame.lon,formation3_alt[i]))
    i=i+1
i=0
    while True:
        if vehicle.location.global_relative_frame.alt >= formation3_alt[i] * 0.95:
    i=i+1
print("Formation4")
# formation4
formation4_alt=[9,6.6,4.9,3.7,3.32]
i=0
    vehicle.simple_goto(LocationGlobalRelative(vehicle.location.global_relative_frame.lat,vehicle.location.global_relative_frame.lon,formation4_alt[i]))
    i=i+1
i=0
    while True:
        if vehicle.location.global_relative_frame.alt >= formation4_alt[i] * 0.95:
    i=i+1
print("Formation 5")
# # formstion5
formation5_alt=[5,5,5,5,5]
i=0
    vehicle.simple_goto(LocationGlobalRelative(vehicle.location.global_relative_frame.lat,vehicle.location.global_relative_frame.lon,formation5_alt[i]))
    i=i+1
i=0
    while True:
        if vehicle.location.global_relative_frame.alt >= formation5_alt[i] * 0.95:
    i=i+1
# # Land the drones.
land()
close()
I am getting dronekit.TimeoutError: wait_ready experienced a timeout after 30 seconds and WARNING: dronekit: Link timeout, no heartbeat in last 5 seconds ERROR When trying to connect 5 drones using com connection using telemetry. I am using Dronekit.
I am using python 3.6.5 and dronekit - 2.9.2
I had this Dronekit.TimeOut.Error a couple of years back. In my case, I didn’t have multiple drones, just 1 quad to worry about.
I needed to go to library where the timeout param is set and change the default parameter from 30 to 60. You may have to experiment to get the correct value.
When running the Python code, you should see the path and library where the message was generated Search the library for “TimeOut” constant and change the parameter. Also make sure you change the correct Timeout constant variable. There were two variables that were similar.
After changing the the timeout constant the code worked.
Hope this helps. Good luck.
in the above code i set the timeout to 300 sec
But still i get the same warning and for some drones i am getting no heartbeat warning
Dronekit is not maintained and is incompatible with more current versions of pymavlink.
Per the course, try dronekit 2.9.1 with pymavlink 2.0.6 in the virtual environment.
Also check
https://dojofordrones.com/ardupilot-connection-issues/
Also is there a typo for ‘import mathPreformatted text’ ?
