I received an FS-i6X Transmitter and X6B Receiver when I purchased the course. The X6B has really no useful documentation or video on how to configure with a Pixhawk. I was expecting something like an IA6B receiver which is depicted in the course videos, which is very straightforward.
In my case, the FS-i6X Transmitter has an RX setup Output mode for Output and Serial options e.g. PWM and PMM, I-Bus, and S-Bus, respectively. There is also an RX setup I-Bus setup option. Not sure what that is for or if needed???
Also, which port on the X6b receiver should be used depends on the options selected in the transmitter, ostensibly, …S-Bus, I-Bus, PWM, and PPM. But which ones should I use???
I tried many of the options but couldn’t get it to work. Has anyone gotten this to work???
Can you help?
