Hello, I need some help. I followed all the steps in run script to Track Aruco and everything goes right until I open a new terminal and go to the RQT. It opens up and I see /camera/color/image_raw, but I can’t find image_new. I don’t see it under the rostopic list. When I go rostopic hz /camera/color/image_new it does not appear to be published. Cant seem to find the problem. Here is my track aruco.py code. Thank you
#!/usr/bin/python
###IMPORT###
import rospy
import cv2
import cv2.aruco as aruco
import sys
import numpy as np
import ros_numpy as rnp
###VARIABLE###
newimg_pub = rospy.Publisher(’/camera/color/image_new’, Image, queue_size=10)
id_to_find = 72 ##Arucoid
marker_size = 20 ##CM
horizontal_res = 640
vertical_res = 480
horizontal_fov = 62.2 * (math.pi / 180)
vertical_fov = 48.8 * (math.pi / 180)
found_count=0
notfound_count=0
###CAMERA INTRINSICS###
camera_matrix = [[530.8269276712998, 0.0, 320.5],[0.0, 530.8269276712998, 240.5],[0.0, 0.0, 1.0]]
time_last=0
time_to_wait = .1
###FUNCTIONS###
def msg_receiver(message):
np_data = rnp.numpify(message)
ids = ''
(corners, ids, rejected) = aruco.detectMarkers(image=gray_img,dictionary=aruco_dict,parameters=parameters)
try:
if ids is not None:
if ids[0]==id_to_find:
ret = aruco.estimatePoseSingleMarkers(corners,marker_size,cameraMatrix=np_camera_matrix,distCoeffs=np_dist_coeff)
(rvec, tvec) = (ret[0][0,0,:],ret[1][0,0,:])
x = '{:.2f}'.format(tvec[0])
y = '{:.2f}'.format(tvec[1])
z = '{:.2f}'.format(tvec[2])
marker_position = 'MARKER POSITION: x='+x+' y='+y+' z='+z
aruco.drawDetectedMarkers(np_data,corners)
aruco.drawAxis(np_data,np_camera_matrix,np_dist_coeff,rvec,tvec,10)
cv2.putText(np_data,marker_position,(10,50),0,.7,(255,0,0),thickness=2)
found_count = found_count + 1
else:
else:
except Exception as e:
print'Target likely not found'
print e
new_msg = rnp.msgify(Image, np_data,encoding='rgb8')
newimg_pub.publish(new_msg)
time_last = time.time()
else:
return None
def subscriber():
rospy.init_node(‘drone_node’,anonymous=False)
sub = rospy.Subscriber(’/camera/color/image_raw’, Image, msg_receiver)
rospy.spin()
if name==‘magic’:
try:
subscriber()
pass
