I’ll start with, I fried some stuff early on. Totally my fault, I had connected an ESC backwards. I’m using the spark-o-lator inline now.
I think I fixed the ESCs and tested continuity on motors (all beeping on all 3 barrel contacts when I test). I think all good, and all four corners beep when drone is powered up.
Doing the ESC calibration;
Turn all dials and zero out remote.
Turn on remote.
Max throttle.
No usb connected to pixhawk; power up drone with battery.
Wait a few sec.
Arm it;; button goes solid red.
Power down; power up.
Wait a few sec.
Arm again to solid red. Hear brown tone.
Lower throttle.
Hear some confirming type sounds.
Turn up throttle to test
all motors begin spinning as per throttle for about one second and then stall out to zero, and remote starts beeping like it lost connection. Sometimes the lights on the pixhawk get dim and it starts acting weird.
I turn off and on remote, it reconnects but drone doesn’t respond.
If it is a brownout, it’s probably the power to the pixhawk, right?
