Hi!
I wonder if you have been able to use bluetooth on your raspberry pi 4?
while scaning for devices i keep getting “No default controller available”. I have you experienced it? and solved it?
Best!
Hi!
Best!
It has been disabled in the config.txt file by dtoverlay=disable-bt, right?
So it might be asked how to enable it and still have serial functionality? You can use /Serial0 in lieu of /ttyAMA0 for the ‘newer’ RPi’s and maybe use miniuart-bt,krnbt=on to use with /ttyS0?
https://raw.githubusercontent.com/raspberrypi/firmware/master/boot/overlays/README
I haven’t had luck with it.
Hi @jax200
What if i use a dongle to connect to the headset and then plug it in the usb port in the pi? Will i then still need to enable the bt in the txt file?
Thanks man! I really appreciete your time
I thought you were referring to the companion RPi used with the drone? Why do you want to use a headset?
If just with the RPi alone there are plenty of tutorials on setting up the bt.
Yes! i am referring to companion RPi used with the drone. But i want to verbally send command to the drone instead of using the computer
I tried to follow these threads but no luck.
https://forums.raspberrypi.com/viewtopic.php?t=261753
https://www.cnet.com/tech/computing/how-to-setup-bluetooth-on-a-raspberry-pi-3/
I can now connect my headphones with the rpi but i could not use the microphone for some reason. so i am looking for other options
So you are aware of Caleb’s latest project here that might help with what you want?
https://www.youtube.com/watch?v=SrLCODU5a8U
I did this on another (option 3):
https://maker.pro/raspberry-pi/tutorial/the-best-voice-recognition-software-for-raspberry-pi
Also see:
https://howchoo.com/pi/bluetooth-raspberry-pi
I have used this to speak into a mic which runs code and displays text on a moving LED display. It asks for a language and what I want to say. It then displays what I say in English in the language I choose and reads it out of a speaker.
i do not have a webbcam so i tried an usb wireless adapter, but still the pi cannot regonise the hardware
Hi @jax200
i followed the video and tried the audio to text on the pi but it failed to find the audio
thx, changed it but still not working.
keep getting recognition request failed: Unauthorized
feedback when i run the script maybe @caleberg knows?
No handlers could be found for logger “playsound”
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.bcm2835_headpho.pcm.front.0:CARD=0’
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.bcm2835_headpho.pcm.surround51.0:CARD=0’
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.bcm2835_headpho.pcm.surround40.0:CARD=0’
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.bcm2835_headpho.pcm.surround71.0:CARD=0’
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.bcm2835_headpho.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2’
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘defaults.bluealsa.device’
ALSA lib conf.c:5036:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM bluealsa
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.bcm2835_headpho.pcm.iec958.0:CARD=0,AES0=6,AES1=130,AES2=0,AES3=2’
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Using device ID 1
Likely that no audio found
^CTraceback (most recent call last):
File “speech_to_text_demo.py”, line 78, in
audio_text = text_from_audio(3)
File “speech_to_text_demo.py”, line 31, in text_from_audio
audio = r.listen(mic,phrase_time_limit=listen_duration)
File “/usr/local/lib/python2.7/dist-packages/speech_recognition/init.py”, line 620, in listen
buffer = source.stream.read(source.CHUNK)
File “/usr/local/lib/python2.7/dist-packages/speech_recognition/init.py”, line 161, in read
return self.pyaudio_stream.read(size, exception_on_overflow=False)
File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 608, in read
return pa.read_stream(self._stream, num_frames, exception_on_overflow)
KeyboardInterrupt
Manage to do some changes but still not working.
here is the response
ALSA lib pcm_dmix.c:1108:(snd_pcm_dmix_open) unable to open slave
Using device ID 1
This might be the issue since i am not using bluetooth
