Barometer Error
I cant seem to arm my drone due to the following error. Seems like the barometer is off?
PreArm: Baro: GPS alt error 5805m (see BARO_ALTERR
All parts are from the build list.
Drone has never flown before, so it could just be broken from factory, I don’t see any calibration options for barometer. I dont even see and values that look related under “status”
Can this be overridden in any way so at least i can fly it some manually?
Been working on this in the little time I have inbetween other stuff for months and havent got it up at all, always on thing or another :frowning:
Has anyone else seen this problem or have any ideas how to fix?
I was not sure, but checked with my friendly CoPilot:
"The error message “PreArm: Baro: GPS alt error 5805m (see BARO_ALTERR)” in the context of Ardupilot and Arducopter typically indicates a discrepancy between the altitude readings from the barometer and the GPS. This can prevent the vehicle from arming as a safety precaution.
Here are some steps that users have found helpful in resolving this issue:
  1. Adjusting the BARO_ALTERR Parameter: Increase the BARO_ALTERR parameter value to accommodate the altitude error. For example, changing it from 5000 to 6000¹[1].
  2. Setting BARO_OPTIONS: Change the BARO_OPTIONS parameter to 1, which tells Ardupilot to treat the barometer as if it’s a different type of chip¹[1].
  3. Hardware Solution: Some users have resolved the issue by replacing the barometer chip (MS5607) with an MS5611, which may require soldering skills²[2].
It’s also noted that downgrading to an earlier firmware version, such as 4.3.0, has helped some users avoid this error¹[1].
(1) Prearm error GPS alt error 5850m (see BARO_ALTERR. https://discuss.ardupilot.org/t/prearm-error-gps-alt-error-5850m-see-baro-alterr/94099.
(2) Prearm error GPS alt error 5850m (see BARO_ALTERR. https://discuss.ardupilot.org/t/prearm-error-gps-alt-error-5850m-see-baro-alterr/94099?page=2.
(3) Arming in altitude hold mode - Copter 4.2 - ArduPilot Discourse. https://discuss.ardupilot.org/t/arming-in-altitude-hold-mode/101030.
(4) Baro: altitude error is linear to altitude #15025 - GitHub. https://github.com/ArduPilot/ardupilot/issues/15025."
Thanks,
When you say CoPilot… as in the microsoft AI or you mean something else?
I tried chatGPT just looking for a place to start and it didn’t really say anything useful . If that’s what you mean by CoPilot I’ll have to try it out.
I’ll try those solutions anyway!
Yes MS CoPilot. I recently started to use it as a troubleshooting tool. I’ve even started to use it with writing code for drone simulation. It often gets it right, albeit sometimes you have to make a few adjustments. I think we are on the initial wave of this. In a year or two it might be the primary means of writing code.
Agreed. I’ve been doing the same with chatGPT on some web/PHP stuff for work and its been amazing.
Cant believe how much it gets right.
closed #6
