It seems that my micro-PiHawk Drone has died. Mission Planner indicates PreArm Battery Unhealthy. I checked the cable between the FC and ESC and the VBAT at the ESC (~ 11V). I replaced the battery, thinking it might be the internal resistance of the old battery (I have flown a lot in the last couple years). Same result.
Next I set the Battery Minimums to zero in Mission Planner. I was able to Force Arm. Props spun for 10 Seconds (Timeout value of 10). Then the props stopped and Mission Planner indicated ‘Bad Battery’.
I have been research replacement stacks (FC/ESC), as it seems that the Matec F405 HDTE is EOL. I landed on the SpeedyBee F405 V4)) and would be interested in any recommendations. I want to use the existing sensors/radio (GPS, Fsky receiver, 915MHz telemetry module etc.).
