Aruco.tester.py
I am trying out the aruco.tester.py that was copied from the github and am having a problem. Disnt change anything in the code, its just straight from caleb github.
When i try to rus : python aruco_tester.py i get this
File “aruco_tester.py”, line 15, in <module>
cap = WebcamVideoStream(src=0, height=height, width=width).start()
TypeError: init() got an unexpected keyword argument ‘width’
cant find the solution. Thank you
This link https://github.com/jrosebr1/imutils/blob/master/imutils/video/webcamvideostream.py shows the code for the WebcamVideoStream object. The constructor method (i.e., the method used to construct an instance of the class) def init(self, src=0, name=“WebcamVideoStream”) doesn’t show height or width arguments; thus, the TypeError: init () got an unexpected keyword argument ‘width’ message.
I don’t have aruco_tester.py. I would like to see if it contains
from imutils.video import VideoStream
If it does, then I believe
cap = VideoStream(src=0).start()
should work.
Could you send a link to the code or the code itself.
Hey Dsetin,Thank you yes I have from imutils.video import WebcamVideoStream.
Yes thanks works great now.
10 points @dsetin19
closed #5
