Hi all!
It worked as expected, I setup de wifi and now I’m able to connect to my raspberrypi thru ssh!
Now, I’m trying to setup the environment in the raspberry, with some versions errors, I am following this post: https://dojofordrones.com/raspberry-pi-pixhawk-setup-steps/
I could follow succesfuly the steps:
- sudo apt-get update
- sudo apt-get upgrade
- sudo apt-get install python3-pip python3-dev python3-opencv python3-numpy
- sudo apt-get install libxml2-dev libxslt-dev
- sudo pip install future (I had to replace it by sudo apt install python3-future…)
- sudo apt-get install git screen
But the next step:
- sudo pip install pyserial dronekit MAVProxy imutils:
matias@raspberrypi:~ $ sudo pip install pyserial dronekit MAVProxy imutils
error: externally-managed-environment× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venvnote: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, b
y passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
I think it is something about python version… but don’t have too much experience on this… is there a newer post?
